Integra cluster Swap????
6psiR1
I have 95% completed a 96 Integra cluster swap into my 92 hatch, but I have a question on the other 5% that isn’t completed. My problem is the fuel gauge; everything else functions properly but the fuel gauge doesn’t respond. I checked the wires over and over again to make sure I didn’t make a mistake. I will post a pin up of the wiring diagram I used if it helps you to see how I wired everything so far.
Also, What are some tips on the mounting of the cluster so it doesn’t look like sh!t. Before anyone starts, I know it will never be perfect; but I just want to see if anyone has any ideas.
Thanks again
well if it was me i would have put the whole dash of a integra in the civic they look sweet in there
Hey guys, thanks for the input. Unfortunately I used that same diagram to wire everything. I checked it over about 10 times and made sure it had a good connection. So what else should I check or are there any other thoughts?
Also, how hard is it to change to an Integra dash? I actually have one. I just thought it would be a huge pain in the ass with all the wiring that needs done.
Thanks again
