let me put it to you this way....the mounts for the 94 integra (b18b) are the same as the mounts for the 93 (b18a).....meaning they should work. we had a member do the swap into a da about a month ago. hopefully he'll see this and post up some info.
THE INFO ABOVE IS WRONG, THE 94-01 MOUNTS DO NOT WORK.
to put an h22 into a da, you need a kit that i have only seen for sale at one place.
