Originally posted by aidan+Mar 16 2005, 01:34 AM-->92b16vx@Mar 14 2005, 06:08 PM
Non vtec SOHC? If so you can swap the appropriate SOHC vtec head onto it with a little work.
You can not swap a B series DOHC head onto a SOHC motor.
[post=473466]Quoted post[/post]
cheers mate taught that all wright mine is a 16valve so it would be a DOHC db61a engin what would u reckin i would have to change would i need a vtec injection system to my car is the zxi model 1.6
[post=]Quoted post[/post]
Originally posted by aidan+Mar 18 2005, 08:46 PM-->Taco15@Mar 18 2005, 02:13 PM
ok first of all slow down. Use punctuations because i cant understand you very well. Do you have a D16a6? If you can post pics that would really help. Here what i have to say from what i can infer, yes you can put a vtec head on a none vtec block. Honda tech (i think) has a good write up on how to do it, along with pics.
PICS WOULD HELP!
[post=475428]Quoted post[/post]
it was a day to get pissed more than we do every other dat yea we do as ther is noting els to do but cruse and get stoned
Originally posted by Taco15@Mar 19 2005, 07:19 AM
UPDATE! ok apparently you have the db6 right? well if im right thats the GSR motor. check this out it might help. Im half awake right now.i just got fucked like never befor and my hands shake as i type.goodnight
http://www.cb7tuner.com/vbb/showthread.php?t=1251 is the link i found.goodnight
Just found a more detailed anwser:
90-93 2dr Integra is DA9
90-93 4dr Integra is DB*..escapes my memory right now
92-93 2dr GSR Integra is DB6
94-01 2dr VTEC integra is DC2
94-01 2dr non-VTEC integra is DC4
94-01 4dr VTEC integra is DB8
94-01 4dr non-VTEC integra is DB4
[post=475617]Quoted post[/post]
ok mate its a 4door 93 integraOriginally posted by Taco15@Mar 19 2005, 01:19 AM
Originally posted by brian11to1+Mar 20 2005, 11:21 AM-->Taco15@Mar 19 2005, 01:19 AM
Get your shit straight:
90-93 Integra Coupe = DA9
90-93 Integra Sedan = DB1
92-93 Integra GSR Coupe = DB2
94-01 Integra Coupe (RS/LS/GS) = DC4
94-01 Integra Sedan (RS/LS/GS) = DB7
94-01 Integra Sedan GSR = DB8
94-01 Integra GSR Coupe/ITR = DC2
Want to know more USDM chassis codes? You should have scrolled down and seen my post, I am BrianDB1. All you have to do to figure out what chassis code goes to what car is search autotrader.com as long as it has the VIN# you will get the chassis code. The Chassis code is the 4th, 5th, and 6th character in the code. damn.
Brian
[post=476012]Quoted post[/post]
cheers mate found out its a sohc 16 valve zc pgm f1 motor the body tipe is a db6 shell 4 doorOriginally posted by Taco15+Mar 20 2005, 05:42 PM-->Originally posted by brian11to1@Mar 20 2005, 11:21 AM
Brian
I just posted what i found, BITCH OUT THE PERSON WHO I COPYED IT FROM NOT ME
. <_<
[post=476176]Quoted post[/post]
