integra gsr trans question
Discussion in 'Integra' started by k20a3rsx, Mar 19, 2009.
  1. k20a3rsx
    k20a3rsx New Member
    ok so im new to the forum here but im also on crsx but i have a question that i need answered i would want to know if a 95 integra ls trans from a b18 a1 would fit a gsrb18c1 what are the pros and cons
  2. eg6sir
    yea, it'll fit... there are no pro's for it ... it'll make you slower because of the longer gearing and dropping you out of vtec when you shift
  3. k20a3rsx
    k20a3rsx New Member
    ok well i know the throw out bearing is messed up on the gsr would the throw out bearing fit from th ls trans into the gsr
  4. k20a3rsx
    k20a3rsx New Member
  5. ls/vtechatch91
    ls/vtechatch91 New Member
    washington
    if there both hydro then ya it will... cable n hyrdo throw out bearings r different
