lets say for a 98 are all these harnesses the same except for GSR and ITR are wired for vtec. And GSR has secondary Butterfly sensor.
Question was wondering if there are any other differences, or are the harnesses basically the same?????????????????
wisemansoji,allmotormonster is the guy who redid my ecu for the b16a2,he did a wonderful job at a reasonable price . also he helped me with the 98gsr harness and 00b16a2 questions I had.call me if you want,this will definately work for you and I'll give ya all the help I can and take whatever pics you could want also,just let me know. EDIT.92b16vx was also a big help for me .
Similar, but not the same. The LS/GS/RS engine harness will have: Coolant Temp Sensor Reverse light VSS O2 sensors (primary & secondary) Alternator Crank angle sensor Distributor IAT sensor IACV etc, etc, etc...... OVER THE LS/RS/GS.... The TypeR adds: VTEC solenoid VTEC pressure switch Knock Sensor Over the TypeR..... The GSR adds: IAB function Of course, that is PROVIDED we are talking about the same year to same year engine harness. I'm not sure what you're trying to do, but there's your answer. Thanks Deth!!
He's got a 94cx and a 00si b16a2.He wants to do what I did and use a integra harness to simplify his swap. and no,please,thank you allmotormonster!!
Ok, got it. He needs a 96-97 DelSol Si VTEC (DOHC) engine harness OR... A 97-01 Type R engine harness OR.... A 96-01 GSR engine harness (yes, you can use this harness) OOps.... EDITED for OBD2 dizzy...
