integra keeps turning of
adanej1
need helps!! i bought a 95 gsr shell with an ls swap. it doesn't have the check engine light on or anything i have a hard time getting it started and and turns of when i step on the gas.... could it b the fuel pump? if it is can i use a civics?
pull the fuel fitter line off and turn the car on.not start it just on and if gas is running out is not the fuel pump...mite need get like a bottle cause it will be alot of gas..Just do it for 3 seconds..
ok when you turn the key on. have radio and anything that makes noise turned off. listed in the back and listen to c if you here the fuel pump. if you dont hear it then thats most likely your problem.
