integra post mount similarities??
Discussion in 'HYBRID -> ED-EF / DA' started by D16SiHatch, Mar 29, 2008.
  1. D16SiHatch
    D16SiHatch New Member
    so heres my dilemma
    apparently the motor mounts on 94+ engines are diff then 93 and lower. The engine mount kits are designed for the older type mounts that have the studs diagonally not directly side by side.
    so basically i need a post mount from a 90-93 integra.
    problem is i cant find one of these at the moment however i did stumble upon a post mount from a b20 and it looks pretty close as far as i can tell. is there anyone who can clarify whether or not i can use this mount? or is the DA mount the only one that will work
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
  3. D16SiHatch
    even if it would fit i cant just bolt the mount down with one bolt. not to mention if i did that the mount would be sitting closer to the block then its supposed to and then it wouldnt be out far enough to then bolt into the chassis.
  4. AHHVTEC
    Alabama
    well what i was getting at is maybe you can remove the right stud if the left hole lines up then tap a new hole for the right
  5. D16SiHatch
    sounds like a ginormous pain in the ass lol. plus how would i ever know if its actually sitting exactly where its supposed to. i could go to drop the engine in the car and then the motor would end up sitting funny because of that mount not bein right. i appreciate the suggestion :) but i guess ill just have to keep an eye out for the correct side post mount.
  6. AHHVTEC
    Alabama
    oh wait a minute is the mount that your holding in your hand a oem mount
  7. D16SiHatch
    nope, its an aftermarket one to swap a b18 into the 4th gen civic/crx chassis. thats my bad i didnt realize i never made that clear.
  8. ls/vtechatch91
    ls/vtechatch91 New Member
    washington
    and what car is this going into?
  9. INJEN78
    INJEN78 HS LEGEND
    OHIO
    im pretty sure you cant use the b20 post mount..you need one from a 90-93...
  10. D16SiHatch
    a 91 si hatch. and to what the other guy said im beginning to think your right. i'll just have to wait till i find the right one that i know works for sure.
  11. INJEN78
    INJEN78 HS LEGEND
    OHIO
    i might be able to get you one,,i gotta talk to my boy n ill let you know
  12. immorality
    immorality New Member
    Can you just drill another hole in your swap mount? It looks like there is room. I'm just about to tackle the same project.
  13. INJEN78
    INJEN78 HS LEGEND
    OHIO
    DO NOT DO THAT!!!!
    drilling holes weakens the metal and there is NOT enough room for a new hole anyway,jus get the correct postmount,,i havent been able to talk to my boy yet,but ill let you know asap
  14. immorality
    I don't see how drilling another hole is going to weaken the mount, but if there is no room for another hole, there's not much point in agruing over it. 90-91 mount it is then.
  15. ls/vtechatch91
    washington
    the da mount is the only one thats gonna work on that... trust i know... i just didnt know what car it was going into... hope that helps.. i wouldnt really recomend drilling a hole.. but if ur desperate and need a car then go for it until you got another one... i've seen alot of weird shit so... who knows
  16. INJEN78
    INJEN78 HS LEGEND
    OHIO
    because the design of the mount is like that for a specific reason,and there isnt enough room for another hole,which would cause you to overlap the existing hole and the new hole,causing metal to bend
  17. ls/vtechatch91
    washington
    ya you'd over lap it but it wouldnt be that much.. still wouldnt recomend it... BUT if hes that desperate then do what u gotta do to get it done until he finds... and if u do... i would recommend using a drill press
  18. D16SiHatch
    i've already payed for and am now waiting for a da mount to be delivered. why you guys still talkin about ghetto rigging a motor mount lol
    if anyone has one of these lying around though, i could sure use it. i'm not sure what to call it, its like a clutch cable bracket i think you might call it. i just took a look at a friends b18a1 up the street and the cable holder looked diff then that so i dont know which one i need or if either will work.
  19. INJEN78
    INJEN78 HS LEGEND
    OHIO
    it is the clutch cable bracket,,,and im looking for one too!!!!ah damn why are they so rare?:D
  20. ls/vtechatch91
    washington
    honda has them.. i had to order mine.. its like 20 bucks with the bolts...
