integra type r motor?? in a ef hatch?
Discussion in 'Civic and CRX - EF' started by civicsir90, Oct 6, 2009.
  1. civicsir90
    civicsir90 New Member
    hey guys i gave up on that weak d15b, and have enough money to buy a type r motor. well thing i just wanna know is that what am i gonna need for the sawp....
    wiring, ect.ect. any ideas will help out great!!!
  2. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    Mount kit, shift linkage, jumper harness, cable to hydro tranny conversion, 90-93 integra driver side mount bracket, 90-93 integra rear mount bracket, wiring for mpfi... these are just the main things I can think of off the top of my head right now...
  3. RoughKnight
    RoughKnight Christmas Car
    Ottawa, Ont
    Check the right forum, the HYBRID forum, use the SEARCH button. This topic has been covered a before.
  4. INJEN78
    INJEN78 HS LEGEND
    OHIO
    Bseries into EF is the next step up from a dseries...its very easy and the most common..
    goodluck and have fun..type-r in an ef is pretty great
  5. 99sidude
    Ohio
    you will need a different hood to fit the taller engine. I believe the jdm hood works great.
  6. B16RacerN2NR
    Moving back West...
    let me touch on this a bit. It all depends on the mount kit. I've seen a few people with hasport mounts have no clearance problems.
    Back when I had my crx, I had the Place Racing mount kit and I was running into a clearance problem with my b16. What I did was I placed a few washers on the tranny mount and driver side mount to drop the motor about half an inch. worked like a charm :) clearance was really close but these mount kits are usually stiff as hell so the motor wouldn't rock back and forth and hit the hood.
