Integra wont start
Discussion in 'Integra' started by mushy, Nov 25, 2007.
  1. mushy
    mushy New Member
    jamaica
    car wont start, battery is good, look under the car noticed i had an oil leak
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    does it even turn over ? more info man
  3. mushy
    mushy New Member
    jamaica
    it turns off but nothing else happens
  4. AHHVTEC
    Alabama
    i mean does the motor turn over does it try to crank but dont
  5. mushy
    mushy New Member
    jamaica
    yeah thats it
  6. AHHVTEC
    Alabama
    ok make sure its getting spark and fuel, and do you have any check codes
  7. mushy
    mushy New Member
    jamaica
    spark is ok so is the fuel no codes
  8. AHHVTEC
    Alabama
    well if your getting fuel and spark theres no reason it shouldnt start.
  9. mushy
    mushy New Member
    jamaica
    i saw oil leaking under it
  10. AHHVTEC
    Alabama
    well if the motor has lost tons of compression it want start.
  11. mushy
    mushy New Member
    jamaica
    if it runs low on oil wat will happen
  12. AHHVTEC
    Alabama
    lots of stuff could like the motor could lock up or blow up,
  13. mushy
    mushy New Member
    jamaica
    if it locks up wat should i do
  14. AHHVTEC
    Alabama
    well it shouldnt be locked up because you said the motor was turning over
  15. mushy
    mushy New Member
    jamaica
    jus in case something like that happens
  16. AHHVTEC
    Alabama
    umm lets see i gues id pull it apart and have it bored out, but to unstick it i gues you could put a little oil in the compression chamber where the sprk plugs go to try and free it up
  17. mushy
    mushy New Member
    jamaica
  18. mushy
    mushy New Member
    jamaica
    if the something wrong with the motor should i jus replace it i have a b18a1 in it right now
  19. AHHVTEC
    Alabama
    what year integra is it, and id find the oil leak, to see what the problem is
  20. mushy
    mushy New Member
    jamaica
    its a 1994 honda integra Esi
