ok i know that intake manifolds arent interchangable but what about throttle bodies? could i use an ls one on a b16 as long as i have the right manifold? also does the obd have to match?
yes, all b series tb's are interchangeable, and no, obd doesn't matter, just make sure the map is on the tb if it is on your current vehicle (older civics/tegs had the maps sesor on the firewall). tps and map plugs are the same style regardless of obd.
