ok so i finally got my car out of the shop doing my rebuild and now there is oil spraying out of the blow off valve.
Ok before i go on any more i'll go ahead and tell you that my turbo seals went bad and oil leaked into the compressor side of the turbo and down into the intercooler and the pipes. that is how it is spraying out of the blow off valve.
ok with that said i think that there is alot of oil in the intercooler and will it be ok if i flush it out with water or something as long as i know it is dry before i start running it again. If i sohouldnt use water then what should i use? thanks for any help you can give me.
