Intermediate shaft help ef b Series?
cardinalboy07
I have a auto b18a that I converted to manual but the DA manual half shaft won't line up with trans (S1) why? Can I use 94 integra intermediate shaft?
WHAT PHYSICAL DIFFERENCE BETWEEN THE AUTOMATIC INTERMEDIATE SHAFT AND THE MANUAL INTERMEDIATE SHAFT FOR DA9??
What year half shaft is that? Your pics suck so I can't see the issue.
Looks like the holes line up on the block.
It should fit fine. The bolt hold look like they line up and you just need to rotate the half shaft towards the block a bit to put the bolts in.
You need the seal in the diff to be from the year that the shaft is from. I did a hydro swap into my DA and at 3am realized I couldn't get my intermediate shaft to seat all the way. It's only a few dollars from honda.
