intermediate shaft trouble
Discussion in 'HYBRID -> EG-EK / DC' started by 97CTR, Jul 10, 2003.
  1. 97CTR
    97CTR Senior Member
    I am almost finished swapping in my 97 ctr engine into my 97 ex. The problem I have run into is that the intermediate shaft that came with the swap just has splines on the end no bearing or anyting to mate with the axles. What do I need. Any info would be helpful. :worthy:
  2. darwins_vtech
    darwins_vtech Senior Member
    Wisconsin
    I think that I had a similar problem with my swap. I did a JDM B16 into a 93 EX. I have a intermediate shaft on the tranny like a GSR does. So I bought both 95 integra LS or GSR Axels. Look a couple of pages back under this forum. and there should be a topic called AXELS - which ones? THat was me. IF you have that same problem get the axels it tells you to. Or PM me and I'll get back to you.
    Darin
  3. phunky.buddha
    Dallas / Fort Worth, TX
    94-01 Integra LS axles should work fine for you.
    AXLE not AXEL
  4. 97CTR
    97CTR Senior Member
    Thanks guys, the driveshaft shop sent me the wrong axles. But now I have got it straightened out.
