I'm swapping a OBD0 B18A into my 89 CRX, it's my first build and swap and my daily driver so I'm playing it pretty safe.
Here's what is going in:
JE Pistons, 10.6:1 CR, 281 grams
ACT Streetlite flywheel
Mild polish (no porting) on IM
B18B cams
JG throttle body
K&N cone air filter
I plan to add the Skunk2 IM later on.
Stock parts unless noted above.
The OBD0 B18A is listed stock @ 132hp and 121lb-ft torque. I am not sure how much more than that I will get, but it shouldn't be that much. (140 - 145 ???) Havn't a clue about increases in torque over stock.
So the question again is: Will the stock clutch work and more importantly, will it last?
B18B cams
JG throttle body
K&N cone air filter
