Is b16 ecu ok on gsr engine?
lohonda
Member
My friend has a gsr block with a b16 head on it. He is currently using a b16 ecu for his engine. I was wondering if that is ok since his engine is 1.8 liters and his ecu is for 1.6 liters. Is there going to be enough fuel for it, or should he get a gsr ecu? Just wanted to see if it is dangerous for him to be doing that.
Thanks.
He has a b16 head on it though so it has the b16 intake manifold, not the gsr.
Also he said that he has yet to hook up the knock sensor, so he has a code for that. So does not having the knock sensor hooked up put it in limp mode or anything else that would limit the performance of it?
He hasn't hooked up the knock sensor yet because his last ecu had a chip that removed the knock sensor, and he hasn't hooked it up yet.
Originally posted by sohcslammer@Oct 25 2004, 07:36 PM
Unless I'm mistaken, it won't open his secondaries either.
[post=407332]Quoted post[/post]​
Once again, you're making us San Diegans look bad.
Please READ the entire THREAD before posting such a reply. This would make everyones life so much better.......
IMO, not enough fuel. Chip the ECU or get a GSR ECU and be donw with it. a 1.8 uses a good bit more fuel than a 1.6.
