Is Ignition Upgrade Worth It?
Discussion in 'Forced Induction' started by Sprocker, Jan 14, 2003.
  1. Sprocker
    Sprocker Senior Member
    I have a turbochaged F23a1 running a low 8 psi, and will be running around 14 once the pistons and rods get here. For ignition right now all I have is the MSD BTM to retard my timing if needed but it isn't the BTM that boosts the ignition. My question is, is it worth getting MSD SCI or 6AL ignition, will it make the car peppier. My other concern is are the MSD ignitions amplifiers, my additional injector controller uses the rmp signal from the distributor and says it can only handle 12V and so I know I can use the RPM signal like I was hooking up a tachometer but is that nessecary! I also have new 2 stages colder spark plugs and new OEM wires.
  2. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    Honda OEM ignition is good up to 500 hp an or 10k rpm
  3. knowledge
    knowledge Senior Member
    Beale AFB, CA
    The stock honda ignition is good. But I am not sure if it is that good. I would get thicker wires and better plugs. The distributor and shit should be good though at that low of a boost.
  4. kamaleon
    kamaleon Junior Member
    if honda ignition is that good.. why did i have to re-gap my plugs from .044 to .035 to aliviate the 'hickup' lack of spark while boosting?!?!?
    or.. im i doing something wrong?
  5. CRX-YEM
    Wallingford, CT
    I'd say stay away from the sci series. you get the same benifits fro ma 6a seies but less cost.
  6. sisteve
    sisteve Guest
    just a small correction
    honda ignitions are good till about 350 hp Their wires are big enough to handle almost anything you can throw at it.
    there really is no reason to upgrade the ignition unless your going for a full race setup.
  7. pissedoffsol
    agreed. the numbers asmallsol posted are from a post i made a while back. i know countless cars in the low 11s and 10s still on stock ignitions.
    i have ZERO intentions on upgrading mine until it is NECESSARY.
    screw the money on it- sell the stuff you got, and get a hondata instead :) you will make more power anyway, and be tuned
  8. cws13
    cws13 Senior Member
    Athens,GA
    It's not lack of spark, it's that the larger gap you listed is too big and you could be snuffing it with boost.
