is it my stater?
team love
red vx (lookout)
it slowly cranks over the more i pump excelerator it cranks faster and faster till it starts once it starts it smells like a bigg gressy egg fart i recently diconected fuel rail to clean injectors on my d15z1 any ideas fuel pump? styarter? ???????
sound slike your battery isn't giving it enought juice.... swap your batter with a friend or your mom or something and see if it fixes the problem.
i whole heartedly agree with b, sounds like a battery problem. might just need to clean the terminals and leads.
mine was doing that the other day and the terminals were just a LITTLE (really) dirty. cleaned em off (after replacing the alternator didnt work) and voila, working car again.
or try a volt meter to you battery. check for 12 volts.
when the car is starting check for amps. about 400 +/-
after the car is running, check for voltage. 14volts
