is my 2k Si revving too high
Discussion in 'Civic and del Sol - EG and EK' started by double0Si, Mar 20, 2009.
Thread Status:
Not open for further replies.
  1. double0Si
    double0Si ლ(ಠ益ಠლ) VIP
    Columbus, Ohio
    I cant remember what RPM my Si ran at when at about 60MPH before the engine swap. Its revving between 3500 and 3750 in 5th and im not sure but it seems pretty high for a stock B16A. And 80 is damn near engaging VTEC at close to 4500. Ive got stock rims with standard sized tires. I know first gear is pretty short but I cant tell if its coming up faster as well. Anybody know what it should be at or is this normal?
  2. FLounder
    FLounder power hungry VIP
    north palm beach, FL
    sounds about right to me... you should be over 4k at 80 mph, all the b16a transmissions are geared low.
    1 person likes this.
  3. Z6CRX
    Z6CRX übber ɐɾuıu etarip
    Pittsburgh, PA
    my b16a crx would be in vtec range at about 90-95 mph.
    so it sounds about right as what mdpsEG said
  4. eg6sir
    at 80mph you should sit at 4400rpm...
  5. eg6sir
    fixed
  6. Z6CRX
    Pittsburgh, PA
    yeah.. i didn't really see it, but knew what he meant
    i think short gears is a better term to use.
  7. MthaFuknGreen
    Lodi, CA
    its revving too high.
    throw it out.
    its worthless.
  8. Dymond
    Dymond New Member
    San Diego, CA
    Swap your 5th gear with an LS tranny?
  9. serrilion
    serrilion In my own little world! VIP
    Vermont
    get a SOHC if ya want not to rev as high and get the mpg, I glady trade ya lol!
  10. Z6CRX
    Pittsburgh, PA
    If you want to get the RPM's lower, swapping out for a GSR or Ls transmission would be easier than swapping gears.
  11. GoTeamVentures2000si
    GoTeamVentures2000si New Member
    Collinsville, Illinois Home of the world's largest
    the gsr's are geared pretty much the same i think. They rev at about 4000 at 70
  12. double0Si
    Columbus, Ohio
    Thanks for the feedback. I'm ok with where its at as long as thats where its supposed to be. I bought a bone stock Si with a ton of miles for something that gets good gas mileage but doesnt bore me to death while I'm not on the GSX-R or in the Camaro. Swapped it with a low mile JDM B16A from tigerjapanese.com and had to convert it to OBD2 so I just wanted to make sure everythings good. Thanks again
  13. shyboi4u
    shyboi4u Junior Member
    Everywhere, MS to AL
    I have a GSR and I'm at 4k at 80. My girl's 00 si is at 4,400-4,500 at 80
  14. eg6sir
  15. double0Si
    Columbus, Ohio
    thank you Dr. Frankenstein!
  16. eg6sir
  17. double0Si
    Columbus, Ohio
    it was meant for the other guy bringing this thread back to life after it was clearly concluded (dead.) therefore... Frankenstein
Thread Status:
