Is my idle normal?
Discussion in 'General Tech and Maintenance' started by BigBoy, May 31, 2005.
  1. BigBoy
    BigBoy Senior Member
    cali 818
    Just bought a b16 ef
    When i turn it on it goes to about 1900 and when i start driving it goes down to 1000. It just seems too high. For example when im on the freeway going 70-75, my rpms are at 4000-4500. And since its got the mugen chip it goes in and out of vtec at 4400. Very annoying. Is this normal?
  2. jamesA
    The idle sounds normal, my a2 idles between 500 and 1000 when it's warmed up.
    Do you mean by "in and out" that vtec engages at 4400 rpm? That seems low, I dunno why they set it there on a stock engine.
  3. Citizen_Insane
    Citizen_Insane Senior Member
    Minneapolis
    Yeah, mine usually runs about 1500 at startup and about 800-1000 once warmed up. Freeway RPM's are high because of the rediculously closed geared b16 tranny, thats completely normal. And finally, get rid of that POS mugen chip. Your VTEC should engauge at 5200rpm (or something like that) not 4400. That low and you'll be losing a lot of power.
    I'd say, double check your vacum hoses and find a stock ECU and you'll be set to go.
  4. BigBoy
    cali 818
    so all i need to do is swap in a stock ecu and thats it?
  5. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Yes, a stock B16A1 ECU, not the one for the car it was swapped into.
