i too have wondered exactly what cars have what iacv before....
still cant tell you what exact engines/cars have which particlar iacv.... all that i have really found out from researching it, is that for the B series there are two styles and they have different bolt patterns. some D series also interchange. the later year models have the wider bolt pattern and the older ones the closer bolt pattern.
You need to find out through Honda. If the parts have different #'s there...I would go with the one for your car. You don't have to buy but ask and compare for a Del Sol VTEC B16A3 (not A2....that's 99/00 civic si) and see what other ones will work. Is there a dealership close to you and you can go in person? You'll usually get a better response.
