i am about to swap my d16z6 to a d15b from hmotorsonline if you guys can go to the website and look at the engine.. it is a jdm vti engine... is it the same as the us d16z6.. or is it different.. because i have heard and read somewhere it is the same just different code. ??
Its basically the same but is a 1.5L and has 130HP compared to 128HP in the Z6. It also uses a one wire O2 but if you run the P28 ECU you'll have to use your 4 wire. Its supposed to have a very good rod to stroke ratio also.
