A friend introduced me to a way about 2 months ago
If you can get the car high enough, (preferably a lift) you can unbolt the upper control arms from shock tower
and the motor/trans mounts, electrical, vacuum, coolant lines (of course). Its really quick if you can get the car up high
enough (after everything is unbolted). I was kinda blown away (although i know this isn't the newest way.
If everything is already unbolted, get a cherry picker and it comes out. Tilt the motor higher then the trans and
it come out with some gentle giggle wiggle (AKA put slack on the trans side like what was stated in the above post)
