is this a good build?
Discussion in 'Engine Building' started by maddog42, Aug 23, 2011.
  1. maddog42
    maddog42 New Member
    im trading for this motor this weekend, so what do you guys think?
    build consists of b16a2 block bored to 82.00mm by buddy rice
    rs machine 8.63cc dome ctr pistons 82mm oversized
    b16a2 crank and rods
    arp rod bolts
    stock windage tray and oil pan
    b16 oil pump
    b18 waterneck
    pr3-4 itr head only 1000k on it
    itr cams
    skunk2 cam gears adjustable
    stock itr dual valve springs
    stock valves
    crome b16 intake manifold
    real itr 98 spec headers
    b16 distributor obd1
    gs-r transmission with f1 racing lightened flywheel
    xtd stage 3 6 puck clutch
    yonaka solid motor mounts for eg
    uncut wiring harness
    stock 240cc injectors
    itr fuel rail
    p28 ecu
    b series axles for eg
    eg shift linkage
    short shifter with stock knob
    stock head bolts
    hastings 82mm piston rings
    king coted rod and main bearings
    12.0 to 1 compression motor
    this motor has never been driven
    i also have a stock gsr and could combined the two if it would make more power thanks
  2. maddog42
    maddog42 New Member
    no imput? how about ideas on combining the two like maybe a poor mans type r
