Is this everything I need for obd0-1 conversion?
Discussion in 'ECU's, Electronics, and Tuning' started by BigBoy, Jul 4, 2005.
  1. BigBoy
    BigBoy Senior Member
    cali 818
  2. brian11to1
    brian11to1 Senior Member
    p30, pissedoffsol has one...
  3. BigBoy
    cali 818
    ANy reason to use p30 and not p28?
  4. jdm2gen03
    jdm2gen03 Senior Member
    either ecu will work, hes jus suggesting that pissedoffsol has one. and u also need to get obd-1 injectors and eliminate the resistor box for the injectors.
  5. MikeBergy
    MikeBergy Blah blah blah....
    Central Coast, CALI
    great buy. good find.
  6. mdixonjam
    mdixonjam Member
    Kingston, Jamaica & Miami, FL
    Why do you NEED to get obd-1 injectors and eliminate the resistor box ???
    Everyone else is saying the conversion will work fine with the obd-0 injectors.
    I did it and kept the obd-0 injectors, but if there is an advantage to upgrading I
    sure would like to know about it !! :worthy:
