Is this header better than stock
Discussion in 'HYBRID -> EG-EK / DC' started by ryaned380, Oct 10, 2009.
  1. ryaned380
    ryaned380 New Member
  2. Matts96HB
    Matts96HB . Moderator VIP
    It looks to be a cheap header, most likely an eBay knock off. Better than stock in the performance aspect, but probably not by much.
  3. phyregod
    phyregod !!YTINASNI
    Central Texas
    It will certainly be better, that looks to be a DC knockoff, which means it will have the same bends and pipe diameter as a DC header, which means the same power gains, but is likely made from cheaper materials and lacking a professional finish. Buy it, port match it with a die grinder, and life will be good. It may only last you 6 or 7 years but lets be honest, will you have the car at that point?
    Also, one way or another you will lose 10 pounds getting rid of that giant cast iron piece.
  4. hunter4life
    hunter4life Rotary Man
    Canada
    ^ Those things do way a ton....by the way not trying to thread jack but just want to throw in a question..at one point we pulled the stock manifold on my buddies d16z6 and it had smaller crush pipe inside? Is this normal??
