does it smoke??? a blue tinted smoke means that hes burning oil, in that case oil is seaping past the rings.
if doesn't smoke, i'd say you got a leak, clean up the motor and run it and then check for leaks around your oil pan or filter.
you guess is as good as mine, what else could you be more specific about?
