is this ok??
Discussion in 'HYBRID -> EG-EK / DC' started by gount175, Sep 3, 2004.
  1. gount175
    gount175 Member
    New York
    are the jdm b16 water and oil pumps good for ls/vtec??....im getting them for a good price....or should i pass them up and go with something else? :huh:
  2. hybrid89
    hybrid89 thistownsucks...
    SoCal
    any DOHC VTEC water and oil pump with flow better than the LS. so to answer your question, yes it will be fine. you might get a little more from a GSR or ITR pump setup, but depending on the cost you are getting them for, its might be minamal. Also remember to use the same timing belt as the oil/water pump used (ie. b16 pumps, use b16 belt).
    matt
  3. gount175
    gount175 Member
    New York
    thanx bro....im getting a b16 block minus internals for 50 bucks
