Is this set up good and worth the money?
Discussion in 'HYBRID -> ED-EF / DA' started by AS_da, Jul 15, 2008.
  1. AS_da
    AS_da New Member
    B16a2 block
    -fully polished and balanced
    -stock rod
    -fully arp bolts
    -ctr pistons
    -custom hg
    B18c1 head
    -toda spec b cams
    -toda built head
    -skunk2 cam gear
    -skunk2 intake manifold
    -type r header
    gsr s80 transmission
    fidanza 8lbs flywheel
    exedy stage 2 clutch
    custom axles
    quilfe lsd
    how much will i make and could i break 12 and what if its in my da?
  2. phyregod
    phyregod !!YTINASNI
    Central Texas
    Building an engine to sell is just a waste of time and a humungus waste of money. Unless you are a well known trusted builder with alot of good rep. you'll never see anywhere near retail for those parts. If you mean 12 as in 12k, you're dreaming. I could see 3k, if you are really lucky.
  3. EF_si
    EF_si do it right
    The Dalles
    I think hes talkin about quarter mile bro. I think you could do at least very high 13's mabe in the low 12's
  4. phyregod
    phyregod !!YTINASNI
    Central Texas
    Ahh, ok. His mastery of the english language pwns me, I suppose.
    Anyhow, who knows. Drive the thing and find out.
  5. BrokenRex
    BrokenRex New Member
    if you're throwing all that money at the thing... why use a b16 block and stock rods? what do you mean by "fully polished and balanced"? do you mean the crank? you'd be much more satisfied if you used a b20 block, or have a b18 bored out to 84mm. the b18 would be cheaper to boot.
  6. Bkkfarang
    Bkkfarang New Member
    Bangkok and Shenzhen
    its a decent list of parts , but again why stock rods , would it do 12s in a da , possibly with the right tune and a good driver , parts don't mean your , fast just that you have the part to be fast
  7. EF_si
    EF_si do it right
    The Dalles
    why not use a gsr block and get internals for that. those blocks are amazing, they are very strong and hat the oil squirters that help with the high revs. maybe some sleeves too. you lookin at some serious cash. it might be cheeper to just build it with low compression stuff and run boost
  8. newb
    newb phresh VIP
    Backwoods Northwest
    Judging by the parts list and the question you asked, Im gunna go out on a limb here and say youre new to Hondas. What you need to do is research, your parts list is off to an ok start, but there is a lot more you need to think about.
    As for the stock rods, if you decide to stick with em, at least go have them shot peened for a lil more strength.
  9. AS_da
    AS_da New Member
    i was asking this question because my cousin ran this in his eg but stock b16 bottom and gsr head with skunk2 cam gear. type r header and gapped pipe and hes alreay seeing low 13s so i was just wondering if i could break 12 with this set up? and no im not selling it for 12k i meant 12 sec 1/4 time!!
  10. brian11to1
    brian11to1 Senior Member
    Jump to conclusions much?
    I agree and you need ARP rod bolts as well. Make sure you have 3 times your budget and another car.
  11. newb
    newb phresh VIP
    Backwoods Northwest
    Werd, I wasnt thinkin. You should get ARP no matter what rods you go with.
  12. AS_da
    AS_da New Member
    no im not new to honda...ive been around it for long now but never liked vtec but after my cousins set up i was wondering what that set up should get cause now im just boosting my ls motor! its fun but i want power all time not later on when your getting close to redline already...like 2.5 or 3.5?
  13. newb
    newb phresh VIP
    Backwoods Northwest
    What? Are you talkin about VTEC crossover, or redline, or what? VTEC doesnt crossover close to redline, it crosses over on the high side of halfway through the RPM range. It might seem like its near redline cuz your car will pull like a mother fucker after the crossover until it hits redline.
  14. TurboRex90
    TurboRex90 Golden EG
    Maryland
    I have Eagle H beam in mine and im running boost, with forged pistons to boot.
    I thought Eagle were a better choice with rods then ARP? i mean yeah ARP bolts/studs like the bolts i have IN MY RODS but rods themselves? eh.. i guess
    *EDIT* my bad, i thought you meant Rods themselves. not rod bolts. dur de dur on my part.
