Is This Tranny Hydro Or Cable?
Discussion in 'HYBRID -> EG-EK / DC' started by NeedACivic, Mar 29, 2003.
  1. NeedACivic
    NeedACivic Member
    Is a 1993 Del Sol tranny hydro? If so will it bolt up to a B18B1?
    Also
    Is a 1997 Del sol tranny hydro? If so will it bolt up to a B18B1?
    P.S. i know it depends on the trim model...But is there a Del Sol tranny that is out of a 1993 that will work? And is there a Del Sol tranny out of a 1997 that will work?
  2. bossman032
    bossman032 Senior Member
    1993 Del Sol is Hydro tranny.
    1997 Del Sol hydo tranny!!
    B18B1 yes if its from a B Series Motor.
    I don't quite get what you are asking but hope above helps...
    check out the references made on Honda swap and articles read and searching is the key!!!!
  3. rsaeini
    rsaeini Senior Member
    Los Angeles, CA
    if the Del Sol has a B-series motor(Del Sol Vtec) than the tranny will bolt up to any B-series motor that uses a hydro tranny. To get more specific, the tranny should work fine with any B18 as long as it is 1994 and up. I think that should answer your question.
