Is What I Have Enough?
evcivic
hey, iam sort of new to swapping and building but i wanna know if what i have is enough.here is a list of what i have , please feel free to add on to what i so far have. this is all for a 98 ek civic
ls block
95 gsr head
95 gsr computer with a mugen chip
b16a2 tranny
11:1 compression je pistons
forged eagle rods
act clutch and flywheel
and a blockgaurd
i would like to run at least 70 to 100 pounds of nos but i really dont know how much should i run
please feel free to add on any suggestions in regards to this. thanxxxx........ :huh:
:huh:
you mean a 70-100 SHOT of NOS?
im not exactly sure about it, but i think you need to set up that ls block to run vtec. need to run the vtec oil pump, knock sensor, and i forget what else. unless that block is already set up to run vtec. if your running nos, i would probably build it a little stronger. dont want to use up $500 in nos shots and then blow the engine. probably get some godzilla sleeves, balance and polish the crank. if you didnt get them w/ the pistons, get some good piston rings. i dont know if the stock valves can take the heat from the shots, i would check, if not then buy some new springs, retainers, and valves. building the engine to take the nos is the main thing.
you will need a conversion cable to run an OBD-1 ECU in your OBD-2 car .... the ECU will not plug into your stock harness
