the car is a 92 si prelude with a h22a swap the vtec solenoid has a blue wire coming out that goes to nothing... where does it go? and egr valve is also disconnected that colors go to what plugs.
you have to wire the vtec, is the oil pressure switch wired? it has to go to the cabin where your ECU is your second question makes no sense to me
did he get a new ecu. i have this same swap in my 92 prelude. what ecu is he running? and yes you have to wire up vtec. there is more to it than just popping in the engine. is the sensor you are talking about that is unplugged on top of the throttle body? post a pic. i can draw it oin there for you.
