there is no alternative to itbs they are a huge performance gain if you have the engine to suport them but first you need to bump the compresion a seroius port job and some serious cams
and with ITBs you have to remember that a tune is absolutely necessary.
You have to get your input mainly from your TPS, not the MAP because vacuum is non-existant with them.since there usually isn't a plenum.
another pro is that they make the meanest sound ever... so nice.
