itr cam
allgo
if i have itr cam, with chip would be the best to use and get most power out of?? i will only have the intake cam.
You could tune a new custom fuel map to suit your new cam, but no, there's not really an OEM chip that's going to make that much of a difference. None of the OEM chips are going to be the "correct" application for your setup anyway.
o ic, i was just wondering because my friend was using a skunk2 chip in his car with itr or ctr cams and just bolts on and he was able to hit mid 13s.
