ITR cams in a b16?
Discussion in 'Engine Building' started by garyeboy, Apr 19, 2008.
  1. garyeboy
    garyeboy New Member
    i have a b16a2 i plan on turbo'ing . i've found a set of ITR cams on the internet they come with springs and retainers and have 59k on them how much they worth? and are these dual valve springs on the itr valve train
  2. garyeboy
    garyeboy New Member
    well considering i think ITR cams are better for all motor and have a bit too much overlap.....how much should i look to pay for some GSR cams
  3. YBLEGAL
    YBLEGAL Regular Member w/ Cheese
    NW Indiana
    lol did you look at my estimated price chart in the other turbo thread u posted in??
    i say around 250 is reasonable for what i've seen. (yeah i'm talkin GSR cams...)
  4. garyeboy
    garyeboy New Member
    sorry i must of looked over that in the other post ,
  5. YBLEGAL
    NW Indiana
    actually, i looked on craigslist just now and it looks more like 100~200 used.
  6. garyeboy
    garyeboy New Member
    thats not bad at all... would you reccomend adjustable camgears along with this upgrade, Has anyone had any experience with the Greddy timing belt is it worth the extra cash
  7. YBLEGAL
    NW Indiana
    yeah it's worth the cash. my buddy runs a greddy timing belt on his fully built 4G63. best thing you can do for an interferance motor just about. toda also makes upgraded timing belts, which is what i'm going with. just throwing that out there too.
    Toda B-series High Power Timing Belt
    adjustable cam gears, i have no experiance with, but i would assume having them wouldnt hurt. at the very least you can set them to stock settings. dont skimp and get cheap ones. do some research as i've heard some brands have problems with the screws not holding it in place and letting them slip out of the intended settings. also, the teeth on the cam gears can be an issue. make sure you get ones with good grooves so they hold the belt and dont let it jump teeth. my friend with the 4G63 had aftermarket cam gears but the greddy belt wasnt recommended to use with those gears because it had tendencies to jump teeth because the gears didnt have pronounced enough teeth.
  8. garyeboy
    garyeboy New Member
    well could you help me out finding cam gears that would work well with the greddy belt?
  9. YBLEGAL
    NW Indiana
    i couldnt say exactly. the stock ones are fine for that belt. as far as adjustable or aftermarket ones tho, no idea. just the particular aftermarket ones he bought (cant remember) had too short of teeth.
  10. 99sidude
    Ohio
    If you are going to tune on a dyno, then getting adjustable cam gears might not be a bad idea. I've heard of people making nice gains by adjusting the exhaust cam timing by a few degrees. Keep in mind this is on boosted setups only where reducing valve overlap can be a good thing.
