SpoonTuNed
I have a b17 and was thinking about putting a integra R crank in to stroke it, but was curious if i still use the b17 rods or what rods should i use? thanks
Originally posted by scottp11@Aug 16 2005, 03:48 PM
Not to thread jack, but can you give me the formula you used to find that out? Thanks!!!
[post=540869]Quoted post[/post]
Originally posted by pissedoffsol@Aug 16 2005, 07:37 PM
how?
simple math
https://hondaswap.com/forums/index.php?showtopic=29828
take the block's deck height, and the crank's stroke, and you can see what you have to play with as far as the rod length goes.
[post=540976]Quoted post[/post]
Originally posted by K2e2vin@Aug 17 2005, 01:16 AM
Swapping the rods in will probally push the pistons into the head, that or you might have a very high compression ratio. Just swapping the pistons will work fine and bump compression up(probally around 10.7:1, which is very good and still very streetable).
[post=541102]Quoted post[/post]
