Itr Cylinder Head
Discussion in 'Engine Building' started by civicracer901, Jan 18, 2003.
  1. civicracer901
    civicracer901 Senior Member
    Clearwater,FL.
    I have a 93 ls bottom end with a 00 crv crankshaft, itr pistons .25 oversized,b16a1 head.Iam not all knowledgeable about building but I wantted to know about swaping the b16 head and putting on the itr head? How would the clearence be on the rods to pistons? :huh: I was also wantting to put on the ctr intake camshaft and the ITR exh. camshaft? I was just curious if this would all work for me? please. :unsure:
  2. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    Yes it will work, it will fit just like the B16 head does. Why are you running a CRV crank? How did you get ITR pistons on LS rods?
  3. pissedoffsol
    thats what i was thinking.... and most of all, WHY??
    and a crv crank is the same as an ls... why did you change it? :blink: :blink:
  4. civicracer901
    Clearwater,FL.
    honda pistons will work with honda rods
  5. prawjEKt Cx
    prawjEKt Cx Senior Member
    upstate NY
    noooooo... certain combos work, i'm not positive on all of them yet, but no, not all honda pistons and rods work together
  6. lsvtec
    Riiiight, you keep believing that. So by your logic I should be able to use NSX pistons on my LS rods, right? :lol:
    The ITR/GSR pistons will not fit LS rods with out modification. Trust me, I tried. CTR, B16, LS, and CRV pistons won't fit GSR/ITR rods. The GSR/ITR rods are smaller on the piston end than LS/B16/CRV rods. So you cannot just interchange between these two groups. Don't get mad cause I called :bs: on your setup.
  7. civicracer901
    Clearwater,FL.
