ITR flywheel vs. ACT flywheel 12lbs.
Discussion in 'Engine Building' started by m2slsvtec671, May 30, 2004.
  1. m2slsvtec671
    m2slsvtec671 Member
    671Guam
    what do yall think is better between a ITR flywheel and a ACT flywheel 12lbs.?? thanks!!!
  2. allgo
    allgo Senior Member
    12pounds. its lighter so faster rev
  3. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    hmm......how about get something chromeoly and light
  4. m2slsvtec671
    m2slsvtec671 Member
    671Guam
    i know lighter the better... lighter no torque... but yea i want torque... so i really want at least 11lbs light or even just a stock itr flywheel which is 14lbs if im not mistaken.. at least its not no stock 18lbs gsr/rs/gs/ls... but a flywheel also just betters the rev or the throttle respond... thanks
  5. H22AdelSol
    H22AdelSol Senior Member
    san diego, california
    you got the money to burn go for the act 12lb, cause its not much of a weight differance from stock yet every lb counts :D
  6. vroomvroomHB
    vroomvroomHB Member
    first i wanna know what you have on your motor, all depends on what you have with it,
    i would prefer to have an aftermarket clutch at the same time
    act street strip baby! with act streetlite flywheel <~~GooD CombO thats what i have. =)
  7. m2slsvtec671
    m2slsvtec671 Member
    671Guam
    well i got the ACT 6 puck clutch still brand new.. but i just ran my car with the clutch only 300miles. and we pulled out the motor for internal work.. soo since the motor is out i wanna jam in some flywheel! but yea probably ima get the ACT 12lbs flywheel. :)
  8. MaaseyRacer
    MaaseyRacer Senior Member
    San Francisco, Ca.
    If you are dying to spend the cash get the ACT, if not get the ITR.
