ITR header
Discussion in 'General Tech and Maintenance' started by egsir, Mar 29, 2004.
  1. egsir
    egsir Senior Member
    Does the itr header fit into the 94-01 integra GSR without problems? I was wondering if the header will fit right up to the cat or do i have to get another pipe to connect the header to the cat? Your replies are appreciated. Thanks :spin:
  2. hybrid89
    hybrid89 thistownsucks...
    SoCal
    a true JDM ITR header has a 2.5" collector that goes to the cat. USDM is only 2". other than that, I believe it bolts right up. I could be wrong though.
    matt
  3. Gen2Teg
    Gen2Teg Senior Member
    san francisco
    naw it won't bolt up. you won't need another pipe, just a small section re-done.
  4. E_SolSi
    :concur:
    you will need to have the cat modified
  5. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
  6. egsir
    egsir Senior Member
    Thanks for the replies. What types of catalytic converters should i use for this set up or what modifications do i need? Do i need to make the modification to the cat where it could bolt up to the 2.5 collector? Thank you
