ITR pistons will lower compression when put in a B16... you want Civic Type R pistons.Quoted post[/post]]
Guys,quick question.Would ITR pistons fit a jdm b16a?If not, what do i need to do?
why are you even asking? I thought you wanted to run stage 2 cams? or are you refering to the CTR pistons? If so, i'm not 100% sure if they fit without modification.Quoted post[/post]]
will they fit with out modifications?
hell yeah more torque,thats nice.thanks guy's.Quoted post[/post]]
the ctr pistons will fit the b16,b18a/b rods with no mod....i would recomend buying them 81.5 and bore the block, this will net you a little more compression and a little more tq...not much but it will
