ITR swap idles @3K
Johnnylawless
I just raced a couple of people and now my idle is up at 3K, also with a bit of vibration but when i drive it it seems to be ok at any rpm above 3k.
I also changed the IAC from My D15b7 to the type r and still no change also tried the MAP sensor and same prob. maybe the TPS gone bad?
Any suggestions greatly appreciated,JIM
It wasn't a sensor it was a vacuum leak from my intake gasket on #1 cylinder.
The bottom Bolt came out. So now I get to put a new gasket on.
Just thought I would give an update so if anbody else ran into a similar situation it might help.
Later,JIM
