Itr Swap
kOOlrean
:ph34r: ima bit confused....im planning on gettin an ITR motor (complete change over) from hmotors online....now what else exactly will i need..?? i want to get as much hasport as possible....soo im getting the hasport: mounts, linkage, axels, ac bracket....
do i need the wireing subharness or will the motor swap come with it from hmotors?? is there anything else i should need, because i want to have everything so wen i g2 the shop i can get it DONE!!!
thanx....
Dj RiiCe :ph34r:
Into what car?CRX?No the motor won't come with a subharness from Hmotor.You have a good list there from HAsport.
Yah its going into a 90 crx si....
so i should buy the subharnes from hasport also?? should i just buy the whole package?? ac bracket subharness ecu etc...????
If you have the flow,make it as easy on yourself as you can.
