Itr Tranny Oil?
Discussion in 'General Tech and Maintenance' started by Jroc2005, May 20, 2003.
  1. Jroc2005
    Jroc2005 Junior Member
    Where do i fill up the tranny oil at for an Itr motor because of 5th gear slippage? and what type should i use?
    Thanks for any help ! :unsure:
  2. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    Use honda oem MTF.................nothing else.....
    Milan
  3. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    use a 3/4" drive wrech to take out the fill plug.. located on the pass. side of the car to the right of the differential...
    i use the same oil in my trans that i do in my engine
  4. Jroc2005
    Alright fellas thanks for the information and help. :D
  5. solblu
    solblu Senior Member
    Ricer
    Or take out the VSS (speed sensor) and put it in at the top of the tranny where you can get to it, you'll still want to take the fill plug out to know when it's full, then put just a little more in for good measure after putting the fill plug back in.
