Itr Vs Gsr Ecu On An Obd2 B16a
Discussion in 'ECU's, Electronics, and Tuning' started by WannabeSI, Jun 15, 2003.
  1. WannabeSI
    WannabeSI Senior Member
    I am trying to figure out what is going on here. I have an ITR and a GSR ecu for my b16a in my 97 civic. I noticed that with the itr i have better low RPM response and I do definitly notice vtec but it is not as powerful in vtec as the GSR. The GSR is really gutless in Lower RPMs but in vtec it abolutely screams. I am not sure why there is such a differece. You would think that the ITR would pick up in vtec the same or faster than the gsr. Is this suposed to be this way or is my car not running right? I guess the better response in lower rpms on the itr make up for the slightly weaker vtec but if there is anything i can do to make it run better i would like to know. Let me know if you have any ideas.
    Thanks
  2. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    those are both terrible ECU's to run on a b16.
    get the proper ECU for it.
  3. chris
    chris Senior Member
    nihon
    itr will run ok, the gsr will run like crap cause its lookin for that secondary butterfly. also wut year ecus and motor? jdm/usdm? no secondary oil pressure switch for vtec salenoid on the jdm motors.
  4. AllMotorMonster
    AllMotorMonster Senior Member
    Inland Empire foo!
    Looking for secondaries huh?
    Somebody call Ripley's because I just don't believe it.
    Why do you just get the RIGHT ecu for your car. They're not hard to find, infact, here's one now, oops, looks like you missed it, but you get the general idea.
    OBD2 P30 ecu on Egay
  5. WannabeSI
    the motor is a 93 Jdm B16 wired for obd 2 (Crank sensor, distributor, alternator, etc) in a 97 civic. the GSR ECU is USDM out of a 97 GSR and the ITR is a 96 and I beleive it is USDM because it is a long one but the guy i bought it from says its JDM. They dont run horrible or anything. I mean it doesnt idle funny or stutter or throw any codes. I dunno
  6. Gen2Teg
    Gen2Teg Senior Member
    san francisco
    you don't always need the proper ECU for the motor, my two friends with ITR's run chipped P28's and it rips a LOT harder than their stock ITR ECU.
  7. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    These are base maps, run a p28 in your ride and let me know the gobs of power you gained.
    Milan
  8. pills_PMD
    New Albany, OH
  9. chris
    chris Senior Member
    nihon
    what dont u beleive regarding secondaries? on the gsr intake manifold or on the jdm vtec salenoid?
  10. pills_PMD
    New Albany, OH
    i think what he is saying is that the ECU wont respond any differently without having the secondaries hooked up.. it will not throw a CEL or anything.. but the fueling / timing for a gsr are not ideal for a b16
  11. AllMotorMonster
    Inland Empire foo!
    Thank you......
  12. pissedoffsol
    can't be. there is no 96 USDM ITR.
  13. ngq
    ngq Member
    if u see A00 or A03 on the ecu its usdm.(A= America)(0 or j=japan)(y=middle east)
    (g=europe)
