ITRs on an EG?
Discussion in 'Civic and del Sol - EG and EK' started by Del Slo, Mar 7, 2007.
  1. Del Slo
    Del Slo New Member
    I am thinking about doing a sway bar swap on my del Slo... First off the history of the car... 94 del Sol S... swapped in a JDM GSR... swapped in GSR brakes (front and rear, yeah I changed the lower control arms to accept a sway bar...) I also Auto-X the car regularly...
    Ok so here is what I'm thinking... I have a factory bar in the front and she pushes like a fat kid in the soup line... I wanna change that... I thought about suspension techniques and intax sway bar kits front and rear but they are about the same size as the JDM ITRs... 25 front and 23 rear... And I kinda like being different...
    Now the problem... my car did not come with a rear bar... I have added the ASR subframe brace and GSR lower control arms... (I believe they are GSR... might be EG... not sure they can with the brake swap)... what else would I need to do the swap besides the sway bars and the bushings?
    I know I will need to get end-links for the rear but what off of? Del Sol Vtec or GSR or Type R?
    Will I still need to reuse the factory mounts for the rear sway bar even though I have the ASR brace?
    Will I need different end-links for the front?
    I have heard from some sites that I need to change the front LCAs to GSR so the bar will mount up... Just like the back....
    Basically I want to have every thing I will need before I start... Thanks in advance for the help...
  2. phyregod
    phyregod !!YTINASNI
    Central Texas
    If it had no rear sway, you will need rear LCAs that will accept a sway bar mount. Other than that, buy a complete ITR rear bar setup (shouldnt put you out more than $100 shipped with end links and all)
    I have no idea what kind of rear brace you purchased, but if it doesnt have rear sway bar mounting holes (to accept the rear brackets) you'll need a binks rear sway install kit.
    Assuming its the same as a 92 civic hatch. Just did that a few months back. I think I was out $235 when it was all said and done.
  3. Del Slo
    Del Slo New Member
  4. Del Slo
    Del Slo New Member
  5. Del Slo
    Del Slo New Member
    What is going on? I have made two posts an they havent gone though?
  6. Del Slo
    Del Slo New Member
  7. thsancho86
    thsancho86 Member
    SC
  8. Del Slo
    Del Slo New Member
    I'm proly getting one from Password Jdm... Rear is like 140 and the front is 80...
    Can anyone give me a definite answer on what i will need?
  9. Del Slo
    Del Slo New Member
    Any help would be great...
