Reopening to add a comment...
The assumption is that B16 pistons fit on the LS rods- there are enough people that have done that. The GSR/ITR pistons do NOT fit the LS rods without modification, so they won't fit in a B16 either.
The B16A and B16B (CTR) do not use the same block configuration. The geometry is the same as the B16A, but the block is the same as the B18C and B18C5. I assume that would mean the rods are the same width as the B18C units (thinner I think), so you wouldn't be able to use those pistons in anything but a B18C block... therefore they won't fit in a B18A/B block. The B16A pistons would, but not the B16B.
That's how I understand it anyway.
Leaving open for further discussion. Any more fighting will result in the reclosing of this thread.
