i've looked EVERYWHERE
Discussion in 'Civic and CRX - EF' started by desert-storm CRX, Dec 6, 2007.
  1. desert-storm CRX
    desert-storm CRX New Member
    winston salem nc
    i have looked all over countless websites and all data and i know i have my ZC swap wired correctly and it will not start.....it shooting codes 6 and 10 and sometimes 15.....i just can't get spark or fuel pulse. PLEASE HELP ME
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    main relay
  3. desert-storm CRX
    winston salem nc
    i've had it tested and it seemed to check out ok but sometimes it will click on and off really fast
  4. dacheat
    dacheat ..is grounded.
    strongbadia
    yeah really it's not too hard to check this one - swap it with one you know works (got any rex friends?) otherwise sink a few bones into a new one and experience the joy of a working relay.
  5. desert-storm CRX
    winston salem nc
    aight i'll check it out next time i'm at the shop...thanx
  6. desert-storm CRX
    winston salem nc
    well i used my buddy's main relay and it still didn't work so i think its because my 91 si ecu doesn't match up with my 88 harness
  7. dacheat
    strongbadia
    well i guess i kinda thought you had it wired up right (including ECU) ala....
  8. desert-storm CRX
    winston salem nc
    well the 88 wiring harness doesn't have a wire for the cyl sensor so the connectors to the 91 computer are sending cyl sensor signals to my crank sensor...i didn't find that out til today
  9. jlicrx
    jlicrx Senior Member
    Colorado Springs
    what model is your CRX? if it is not Si, you need to do the DPFI to MPFI wiring changes to it - won't matter what year it is
  10. desert-storm CRX
    winston salem nc
    its an 88 si harness and a 91 crx si ecu
