J Spec B16a Running Problems
Discussion in 'General Tech and Maintenance' started by possessed imports, May 17, 2003.
  1. possessed imports
    possessed imports Banned
    i am having a problem with my motor. it is a first gen b16a j spec motor. now my problem is when i start it in the morningit has a hesitationfor a quick second then everything seems ok. i can drive the hole day with no problems, but if i push it after a awile it starts back firing the rpm meter will drop to zero and if i give gas it will die down or shoot fire balls. this was an early problem. now, it starts up the same in the morning but the time that it starts acting up shorten and the car sounds like it wants to shut off and when i give gas a little bit of smoke puffs out.
    WHAT IS THE PROBLEM????????????????? :( :angry: :( :angry: :unsure: :unsure:
