J30a
Discussion in 'Accord' started by smokeshow, Jan 7, 2007.
  1. smokeshow
    smokeshow Junior Member
    What mods can be done to this thing. I can't find much of anything but cams from the J32A Acura CL... Is a turbo kit even out there? Is there a manual tranny available? LSD?
  2. powerdriverh22
    powerdriverh22 Senior Member
    spfld, mo
    yes there are manual trannys that work. new accord and acura tl trannys will work (so ive heard). but no the j series v6 is a horrible base motor. there are very very few parts for them
  3. snoopyloopy
    snoopyloopy New Member
    Killa Cali
    from what i hear, all the turbo projects on the j motors end up being disappointing. supercharger would probably be a better idea if you can find one.
  4. smokeshow
    That sucks... I will tell my friend to look elsewhere if he wants to go fast then..
    Thanks guys!
  5. doc500
    doc500 New Member
    If you look at 1/4 mile times v6 accords are in the 15s already. If you do some research more power can be extracted. Comptech makes a supercharger I believe for the J motor.
  6. BrutalB83
    Rochester Hills, MI
    This thread is from 2 years ago. Next time, check the date before you hit "reply"...
