J32A Swap
Discussion in 'HYBRID -> EG-EK / DC' started by 95EG9, Mar 10, 2009.
  1. 95EG9
    95EG9 New Member
    Summerville, SC
    Hey I just bought a J32A Engine out of a 2001 Acura TL. I am working on getting the rest of parts to swap the enigne into my 95 Civic Sedan. I am having a lot of trouble finding a 6 Speed manual transmission for it. If anyone knows where I can find one please let me know. I am planing to put the TL type-s cams in it also. Rebuild the whole motor and put light boost to it. If anyone knows anything about the swap that could help me just let me know. Anyones help would be greatly appreaciated. Thanks!
  2. Z6CRX
    Z6CRX übber ɐɾuıu etarip
    Pittsburgh, PA
    Hasport Performance Online Store
    mounts are listed for 04-08 TL 03-07 Accord manual transmission though.
    Pretty much its tracking down a 6speed on forums, locally, junkyards, and ebay.
    Also this swap will be much more expensive than most.
  3. Briansol
    its going to cost you like 15 grand to get a v6 into a civic. why bother.... buy a v6 accord or something
  4. Briansol
    and there weren't many manual tranny v6's offered at all, so, good luck finding a 5 speed one, let a lone a 6 speed one. i'd bet that vast majority of those cars are still on the raod.
  5. |Chaz|
    |Chaz| Well-Known Member VIP
    Of all the swapping routes to go why would you choose this one?
  6. sufikation
    sufikation Active Member
    Fruitland, ID
  7. tegman88
    tegman88 New Member
    spartanburg sc
    dude do some more research before you make a reply to something theres plenny of donor cars for a 6speed tranny 3.2tl cl and v6 accords come 6 speed and its really not that much you can do a j series swap for cheaper than a k swap if you know what your doing
  8. Dark93DX
    Dark93DX New Member
    B.C.
  9. eastbxc
    eastbxc Custom User Title
    Kansas
    Which 98% of the people have no clue how to do half the custom fab work you would have to do. It may be cheaper to buy the motor but it doesn't mean it is going to be cheaper to do the swap.
  10. BrutalB83
    Rochester Hills, MI
    I'm going to relish this opportunity to correct some of the regulars here since it doesn't come around too often! :D
    Hasport actually does make mounts for this now, and other companies are offering wire harness conversions and suspension components, so this actually can be done relatively easily now. It's no longer a custom hack job like it used to be...
  11. kricket3000
    kricket3000 New Member
    last issue of honda tuning had a whole write up on this swap, plus parts list.
  12. eastbxc
    Kansas
    Yeah but it is still going to require a lot of more custom fabrication.
    What issue was that? I saw they mentioned talking about the Hasport kit over the summer.
  13. BrutalB83
    Rochester Hills, MI
    Do you know that for a fact, or are you just assuming?
    I already know the answer, but I'd like to see how you're going to respond before I say anything...
  14. |Chaz|
    This ought to be interesting...
  15. Briansol
    Sure, they exist. but like i said, good like finding one.
  16. eastbxc
    Kansas
    I am assume because that is a lot bigger engine to fit.
  17. Z6CRX
    Pittsburgh, PA
    obviously you'll need to cowl the hood
    you can do it like I did with my h2b in my gallery by taking steel and just cutting the hood to raise it, then you have to do axles(ask hasport since they made the mounts), shifter and ecu.
    Hondaswap Gallery
    If you have the funds and are willing to do it, go for it, people say its different, but it really isn't. Obviously if a company "commercially" makes mounts then its a good chance there was enough demand to offset the costs to draw them out. Your biggest cost is probably going to be the transmission though.
    just write out a list of what you EVERYTHING you will need, price it and add 2,000 to it to be safe
    probably should upgrade the brakes and suspension a bit to handle it a bit better.
  18. BrutalB83
    Rochester Hills, MI
    Well you shouldn't assume. It's essentially a bolt-in swap with the mount kit. The only fabrication needing done is very minor. You have to reposition one of the engine bay mounting points, and that's it. It's basically no more work then an H22 swap. Actually, it's somewhat LESS complicated then an H22 swap, because they have a mounting plate that allows you to bolt in the shifter with no fabrication, and you don't even have to dent anything in the engine bay for clearance.
    So yeah, next time, check before you assume...
  19. eastbxc
    Kansas
    Well I am sorry I upset you no need to be an ass about it. I wasn't even trying to act like I knew all about it all I said was it required some custom fab.
  20. BrutalB83
    Rochester Hills, MI
    If I was trying to be an ass about it, then I would have called you a dip-shit or knob gobbler or something else to that effect. My point was that you obviously didn't know what you were talking about, so therefore you shouldn't be acting like you did.
    If that makes me an ass, then so be it... :dunno:
