J32A2 engine in 97 Accord.
Discussion in 'Accord' started by elliottworldwide, Nov 17, 2006.
  1. elliottworldwide
    elliottworldwide New Member
    Hello all,
    I'm new to the site. I have a 1997 Honda Accord EX coupe with a 2.2L Vtec engine. I'm looking to do an engine swap and I want to get the most HP possible in a swap. I work at a big auto shop, so money and labor is not an issue. Is the J32A2 from an Acura 3.2CL Type-S a good swap? It'll bring my 145hp 2.2L to a 260hp 3.2L. Will the mounts match up? What else is needed? Wondering if anyone has seen this done...thanks!
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    just put a h22a in there the 220hp modle it will drop right in and hook right up you can even use the accord tranny if you wont to
  3. BrutalB83
    Rochester Hills, MI
    A better choice than the V6 would be a K24 from a TSX, or a K24 block from the newer Accord or Element paired with an RSX Type-S or Type-R head. Either of those setups would net you around 200 horsepower right off the bat, plus they respond excellently to tuning. A motor like that, when paired with intake/header/exhaust, some cams, possibly some headwork, and a good tuning with k-pro or something similar would net you V6 power plus it will be a much easier install. With that V6 you're looking at a completely custom install, whereas they have mounting kits available for swapping a k-motor into an Accord.
    That's what I would do if I were you.
  4. elliottworldwide
    Where is the best place to pick up a 260hp H22A?
  5. AHHVTEC
    Alabama
    theres no such the best is 220hp. hmotorsonline.com
  6. elliottworldwide
    Sorry about that, meant 220hp.;)
  7. BrutalB83
    Rochester Hills, MI
    *Cough* K24 would be better and easier to make power on *Cough*
    The 220hp version of the H22 is a lot more expensive then most other versions of the motor, plus it's a nightmare to wire up. I'd either go with a standard 200 hp OBD2 H22 swap or just go all out and go the K24 route, much better motor than the H22 in my opinion. Like I said, with bolt-ons and some headwork and tuning you can make numbers in the range of 250ish horsepower. Add some boost, and you're looking at 300-400 hp depending on your boost levels, and that's on stock internals.
  8. AHHVTEC
    Alabama
    i like the k series better also but it will cost about 7-9 grand by the time is going
  9. powerdriverh22
    powerdriverh22 Senior Member
    spfld, mo
    the j series v6 will not in any way shape or form mount up to your chasis.
    my h22 with a few bolt ons has no problem with the k20 civics and rsx's
    if you have the money the k24 bottom end with a k20 head would be the best way to go, those motors are extremely efficient.
  10. AHHVTEC
    Alabama
    also the 94+ accord came stock with v6 motors so it might fit but im not sure
  11. BrutalB83
    Rochester Hills, MI
    Nope, won't work. The 95-97 V6 Accords had slightly longer front ends to fit the larger motors. That V6 that they put in it was different than the current J-series motors also, I think it was a C-series and it only made like 175 hp and only available in automatic, so basically it's a piece of junk in my opinion. You'd be better off with an H22 swaped Accord than the 95-97 V6 Accord.
  12. powerdriverh22
    spfld, mo
    correction 95+ and yes they are the c series not the j.
    the chassis is also different on the v6 (95-97) accords than the 4 cylinder. the v6 wouldnt fit. they had to lengthen the nose 3 inches to get the v6 in there
  13. AHHVTEC
    Alabama
    ahh yea darn i remeber now,, and yes its a c series
